What, exactly do you mean about Nano Din rail patch panel
Din rail patch panel | Din rail mount liu | Din rail enclosure
Unisol Din rail patch panel is an integrated unit for fiber management, these equipment functions are to fix and manage the fiber optic cables inside the box as well as provide protection. These are the fiber enclosure that can mount on a standard 35mm DIN rail frame. These patch panels are suitable for mounting in Din Rail panels where there is space constraint inside PLC’s. Because of its compact and rugged designed case, it is ideal for industrial applications.
Design:
UNISOL Din rail patch panels are designed to meet industrial applications for fiber connectivity.Din Rail patch panel contains three parts, the detachable front panel that includes multiple types of fiber adapters which gives access to connect with Optoelectronic device and the other compartment that holds fiber optic splice trays for fusion splicing which accommodates splice protection sleeves and space for excess fiber and pigtail routing. The most critical part is Din Rail base which mounts/fixes the patch panel on to the 35mm Din Rail frame.
Construction:
Our Din rail patch panels are fabricated with advanced manufacturing process using Robust steel/aluminum construction with seven tank process pretreatment and electrostatic spray technique powder coating, which ensures the highest level of protection for sensitive components inside the enclosure and increases corrosion resistance for harsh environmental conditions. Multi-port cable entries allow greater flexibility for interconnecting practically two units of outside plant distribution cables. The rugged PVC/metal Din Rail base ensures proper mounting into Din Rail frame. It has a load capacity of 5kg to15kg.
Advantages:
Din rail patch panels are compact in size and can be mounted in a cabinet with other din rail equipment. These economical series of compounds are the perfect choice for terminating fiber data cables where the expense of an outdoor enclosure is not desired. Din Rail mount enclosures keep the patching close to the active equipment, it serves and minimizes cable management in the cabinet. These boxes are perfect for transitioning outdoor rated to indoor rated cables without the need to install an entire rack enclosure or panel system. These compounds can be used to provide a maximum number of fiber connections in a minimal footprint.
Types of Din Rail mount fiber optic patch panels
  • Nano din rail patch panel
UNISOL Nano Din rail patch panel is designed to support fusion splicing or direct termination of the fibers. Nano Din Rail enclosure can help where there is space constraint and limited connectivity up to 6 port with SC/ST/LC type of connector is required, which reduces the cost and space inside the panel. Because of its compact and rugged designed case, it is suitable for industrial applications. The device includes a splice tray for fusion splicing and ideal for mounting on 35mm Din Rail Panels. Din rail mount fiber patch panel is used to provide a maximum number of fiber connections in a minimal footprint. These type of enclosures are also suitable for CCTV & surveillance applications.
  • Micro Din Rail Mount patch panel
UNISOL Micro Din rail patch panel is designed to support fusion splicing or direct termination of the fibers. Micro Din Rail enclosure can support up to 12 port terminations in SC/ST/LC type connectors. Because of its compact and rugged designed case, it is suitable for industrial applications. The device includes a splice tray for fusion splicing and ideal for mounting in 35mm Din Rail panels where there is space constraint inside PLC’s. These enclosures are also suitable for CCTV & surveillance applications.
  • Miniature Din Rail Mount patch panel
UNISOL Mini Din rail patch panel is designed to support fusion splicing or direct termination of the fibers. A miniature enclosure can support up to 24 ports in SC/LC type connector where there is maximum no. of fiber links are required with multiple fiber cable inputs. Because of its compact and rugged designed case, it is suitable for industrial applications. These enclosures include a splice tray for fusion splicing and ideal for mounting in 35mm Din Rail Panels. Din rail mount fiber patch panel is used to provide a maximum number of fiber connections in minimal footprint where there is space constraint inside PLC’s.
Applications
Din rail patch panels are used in Power Systems & Controls, Oil & Gas Industries, Rail signaling & Control Systems, CCTV & Surveillance Applications. Outside Plant, Mining & Military, Road & Rail, Ship & off Shore, Transmission boxes for a substation. CCTV traffic monitoring, Toll systems, and environmental monitoring equipment. Machine Building, Transportation, Alternative Power Generation like Solar, Windmill, Power Transmission & Distribution, etc.
Conclusion
Din Rail patch panel plays a crucial role in the field of fiber communication network in the automation industry with greater safety and versatility. It is a good option because it can help you to organize and connect the fiber optic links, and it can protect the cables from damage. Din Rail enclosure can support where there is space constraint which reduces the cost and space inside the panel. These Din Rail series of cabinets are the perfect choice for terminating fiber data cables where an outdoor enclosure or rack mounting option is not accessible.
