What is a cage valve?
A cage valve uses a piston with piston ring seal attached to the single seated valve “plug”. Here the hydrostatic forces acting on the top or the piston or below the valve plug tend to cancel out. The seat ring is clamped in by a cage. Cage valves are generally used for noise reduction.
