What is a multimeter?
A multimeter or a multitester, also known as a VOM (Volt-Ohm meter), is an electronic measuring instrument that combines several measurement functions in one unit. A typical multimeter may include features such as the ability to measure voltage, current and resistance. Multimeters may use analog or digital circuits.
The instrument, which contains a function switch to connect the appropriate circuits to the d’Arsonval movement, is often called a multimeter or ampere-volt-ohm (AVO) meter or volt-ohm-milliammeter (VOM).
