Strain gauges are simple sensors that can be used to measure forces. They consist peice of conducting material that changes resistance as it is stretched in a given direction. The diagram below shows this:
Circuitry
Typically, the change in resistance of the strain gauge is very small. In order to accurately measure this small change, special circuitry is needed. For this, a wheatstone bridge configuration is usually employed. There are variants on how this circuit can be arranged; two are presented below.
The first configuration is the simplest method. The wheatstone bridge measures small imbalances in the resistances. Here it is comparing the strain gauge resistance to R 3, which has a resistance equal to the resistance of the unstretched strain gauge. The other two resistors should have similar values.
Next is a more advanced circuit used for measuring strain in both directions. Two strain gauges are used, and must be positioned carefully, as shown in the second figure.
