What is a Transducer?
Transducer is defined as an element when subjected to some physical change experiences a related change or an element which converts a specified measurand into a usable output by using a transduction principle.
It can also be defined as a device that converts a signal from one form of energy to another form.
A wire of Constantan alloy (copper-nickel 55-45% alloy) can be called as a sensor because variation in mechanical displacement (tension or compression) can be sensed as change in electric resistance. This wire becomes a transducer with appropriate electrodes and input-output mechanism attached to it. Thus we can say that ‘sensors are transducers’.
