What is a zero Check and static Zero Check on a DP Flow Transmitter?
Zero Check: A procedure for checking the transmitter output is equal to 4.00 mA when its HP & LP chambers are equalized and are at the atmospheric pressure.
Static Zero Check: A procedure for checking the transmitter output is equal to 4.00 mA when its HP & LP chambers are equalized and are at the operating pressure.
