What is automation ? | History of Automation
Benefit of automation is that it saves labor; however, it is also used to save energy and materials and to improve quality, accuracy and precision.
Automation is basically the delegation of human control function to technical equipment for
  1. Increasing productivity
  2. Increasing robustness (consistency)
  3. Reducing direct human labor costs and expenses.
  4. Increasing quality
History of automation
Manual Control
Pneumatic Control
Hard wired logic Control
Electronic Control using Logic Gates
Programmable Logic Controller
1. Manual Control
All the actions related to process control are taken by the operators manually.
Disadvantage
Likely human errors and consequently its effect on quality of final product.
The production, safety, energy consumption and usage of raw material are all subject to the correctness and accuracy of human action.
2. Pneumatic Control
Industrial automation, with its machine and process control, had its origin in the 1920s with the advent of "Pneumatic Controllers“.
Actions were controlled by a simple manipulation of pneumatic valves, which in turn were controlled by relays and switches.
Disadvantage
Bulky and Complex System
Involves lot of rework to implement control logic
Longer project time
3. Hard wired logic Control
The contactor and relays together with hardware timers and counters were used in achieving the desired level of automation
Disadvantage
Bulky panels
Complex wiring
Longer project time
Difficult maintenance and troubleshooting
4. Electronic Control using Logic Gates
In 1960s with the advent of electronics, the logic gates started replacing the relays and
auxiliary contactors in the control circuits.
The hardware timers & counters were replaced by electronic timers.
Advantage
Reduced space requirements
Energy saving
Less maintenance & greater reliability
Disadvantage
Changes in control logic not possible
More project time
5. Programmable Logic Controller
In 1970s with the coming of microprocessors and associated peripheral chips, the whole process of control and automation underwent a radical change.
Instead of achieving the desired control or automation through physical wiring of control devices, in PLC it is achieved through a program or say software.
The programmable controllers have in recent years experienced an unprecedented growth as universal element in Industrial Automation.
It can be effectively used in applications ranging from simple control like replacing small number of relays to complex automation problems.
Advantages of PLCs
Reduced space
Energy saving
Ease of maintenance
Economical
Greater life & reliability
Tremendous flexibility
Shorter project time
Easier storage, archiving and documentation
Industrial automation main components
Field instruments
Control hardware
Control software
Automation : Typical installation…
|640x480
|640x438
Sensors or Transducers (Field Instruments)
Sensors are used to sense the changes in physical parameter like Temperature, Level, Flow, Humidity, Pressure and many others…
Transducers are used to convert not electrical quantity to electrical signals
Hence it concludes, sensors and transducers are placed in field to sense the physical parameters and send the electrical signal of respective changes to control rooms.
These signal are either digital or analog signals for example, Ohm(RTD), mv(Thermocouple), standard 4-20mA signal, etc.
Widely used field instruments in industries
Flow transmitters (Orifice, Ventury, Electromagnetic flow meter etc)
Pressure transmitters (Bourdon gauge, Bellows, Diaphragm, etc)
Temperature transmitters (Thermocouple, RTD, Thermister, etc)
Level Transmitter (Ultrasonic transmitter, Radar type, capacitive type)
pH transmitter
Conductivity Meter…etc
Famous manufacturing companies (Field instruments)
Fisher Rosemount
Yokogawa
Endress+Hauser
Forbes Marshall
Honeywell ABB
Control hardware
Standalone PID Controllers
Programmable logic controllers
Distributed control system
1. Standalone PID Controllers
|125x200
These are the small controlling hardware which fulfill the requirement of closed loop.
This can be installed in field or in control room
Every companies have variations in programming patterns to setup PID configuration
Typical installation of standalone PID controller
\ 640x299
Master slave communication with RS485
Famous manufacturing companies in PID controllers
ABB
Yokogawa
Moore
Forbes Marshall
Honeywell
Eurotherm
ASCON
2. Programmable logic controllers
\ 320x228
PLCs
A programmable logic controller (PLC), or programmable controller is an industrial digital computer which has been ruggedized and adapted for the control of manufacturing processes, such as assembly lines, or robotic devices, or any activity that requires high reliability control and ease of programming and process fault diagnosis.
What is inside PLC ?
\ 640x324
Architecture of PLC
A programmable logic controller (PLC), is a like a microcontroller which is used for doing so many applications.
It basically consist of
  1. CPU with processor and program memory
  2. Power supply
  3. Input module
  4. Output module
  5. Control bus
1. Parts of Delta PLC
|640x568
2. Parts of Allen Bradley PLC
|640x564
3. Parts of Siemens PLC
|640x568
4. Parts of Zelio Schneider electric PLC
|640x402
Distribution of I/O’s through controller
|640x298
Distributed control system (DCS)
\ 640x390
General architecture of DCS
System cabinets and Marshalling cabinets of DCS
\ 640x386
System and Marshalling cabinet arrangement
Various DCS and Hybrid DCS providing companies
DCS
  1. Yokogawa (Centum VP)
  2. Honeywell (EPKS)
  3. Emerson (Delta V)
  4. Forbes Marshall
Hybrid DCS
  1. Allen Bradley (Compact logix and control logix)
Various Communication protocol used in DCS or PLC systems and its hierarchy
|640x298
LAN (Ethernet)
Modbus, CAN, Serial communication
OPC (OLE for Process Control)
Control NET
Foundation Field bus
Profibus (DP,PA)
Device NET
Various languages used in PLC and DCS
Ladder Logic ( LAD/LD)
Function Block Diagram (FBD)
Sequential Function Chart (SFC)
Structured Text (ST)
Instruction List (IL )
Supervisory Control and Data Acquisition software (SCADA)
               SCADA (supervisory control and data acquisition) is a category of software application program for process control, the gathering of data in real time from remote locations in order to control equipment and conditions.
Features of typical SCADA software
Dynamic process graphic
Real-time and Historical trending
Alarms
Recipe Management
Security
Device connectivity
Script for logic development
Database connectivity
Displays used for monitoring in SCADA systems
|640x408
|640x458
Some SCADA software available in market
Intouch (Wonderware factory suit)
Wincc (Siemens)
Simplicity (GE Fanuc)
RS View32 (Allen Bradley)
Flow of project in industry
|640x417
Core branches/career of Instrumentation and its scope in Industry
JOB OPTIONS
EPC
Engineering Procurement and construction
Designing of total plant
Automation work includes in EPC companies
Designing of P&ID drawings
Automation
Designing of the Automation system
Erection and Commissioning
Maintenance and Troubleshooting of existing system
Author - Tushar Bhaskarwar
