The proper definition for bench set is the inherent diaphragm pressure range, which is the high and low values of pressure applied to the diaphragm to produce rated valve plug travel with atmospheric pressure in the valve body.
This test is often performed on a work bench in the Instrument shop prior to placing the valve into service and is thus known as Bench set.
