What Is Difference Between PLC And CNC?
CNC (Computer Numerical Control) is a particular application usually to control a multi axis machine tool such as a milling machine or a lathe but also could be a tube bending machine punch press or similar. The CNC controller is usually a purpose built controller using a micro computer but could be a general purpose computer or a PLC. The forerunner was NC (Numerical Control) before computers were readily available, it used solid state logic and relays, timers etc to provide the application.
A PLC (Programable Logic Controller) is a general purpose logic controller specifically designed to allow the user to create their own application. They select appropriate I/O (Inputs Outputs) and perhaps function modules for purposes such as communications and multi axis servo control and program the PLC to perform the required functions.
This is good,
More explanations in depth.
Good work there.
