What is Examine if closed (XIC) Instruction in PLC?
Use the Examine if closed (XIC) instruction in your ladder program to determine if a bit is on.
  • When the XIC instruction is executed, if the bit addressed is on (1), then the instruction is evaluated as TRUE.
  • When the XIC instruction is executed, if the bit addressed is off (0), then the instruction is evaluated as FALSE.
Alternate name: Normally open contact
