UNISOL 2U Sliding Rackmount patch panel is suitable for 19” Rack frame applications where the Fiber optic backbone cable has to be terminated and had an option for sliding for easy maintenance.
2U Sliding Rackmount patch panels slide-out tray holds 4 adapter panels & It can accommodate 96 port in 2U size where there is space constraint in the rack. The Fiber spool provides a minimum bend radius and the splice tray provides protection for splice joint. 2U slide-out Fibre optic patch panel rack mount suitable for easy pull-in & pull-out to manage the interior of fiber LIU.
2U Sliding a rackmount patch panel is an integrated unit for fiber management, we offer slide-out rack-mounted fiber optic patch panels, this equipment function is to fix and manage the fiber optic cables inside the box as well as provide protection.
Our fiber patch panels are made with 16-gauge mild steel with corrosion-resistant seven tank process powder coating to provide excellent protection for the inside fibers. Our 2U Sliding Rackmount patch panels can accommodate up to 4 modular panels and are equipped with cable spool to limit bend radius and enhance strain-relief control. Unisol 2U Sliding Rack mount patch panels are designed to accommodate a maximum of six cable entry.
It can support up to 96 ports when fully loaded with SC Duplex or LC Duplex Adapters. The fiber optic patch panel rack mount provides cross-connect and interconnects capabilities for splicing & terminating optic fiber cables, pigtails in a fiber access network. Patch panel can be loaded with a variety of adapters like ST, SC, FC, and LC.
Applications:
- Indore Premise Networks
- Central offices (FTTx)
- Data Centers
- Telecommunication Networks
- Security Surveillance Applications
- Process Automation & Control
- Systems
- Power Systems & Controls
