What is Stilling Well?
Stilling well is a cylinder shaped cage installed within a tank to protect level instrumentation such as displacer from fluid agitation that would result measurement error.
What%20is%20Stilling%20Well
The stilling well should be perforated (provided with holes) to allow the level of fluid inside and outside stilling well within a tank be always equal.
Stilling well shall have diameter with size providing adequate gap between stilling well and displacer. This is to avoid liquid or particle being clogged in between.
