What is the difference between a gate and a globe valve?
A valve is simply a device that directs or regulates flow by opening, closing or partially obstructing passageways.
Gate Valves
Gate valves, the most common type of valve in the industry, are valves that open by lifting a gate out of the route of the fluid. Gate valves are designed to be fully open or closed; they are regularly used as a block valve for isolating pipe systems.
When a gate valve is open, there is no obstruction in the flow path resulting in very little friction loss. Gate valves are used when a straight-line flow of fluid and minimum restriction is desired.
These can be controlled by a hand-wheel, air powered diaphragm, electric motor, or a piston actuator.
Globe Valves
Globe valves are used for regulating flow in a pipeline, instead of having the “all or nothing” function of a gate valve. Globe valves regulate by the position of a movable disk (or plug) in relation with the stationary ring seat.
A globe valve may have ports that run straight across, or may be pointed at an angle. This type of angled supply valve is commonly used for corrosive or thick, viscous fluids that tend to solidify. Having outlets on an angled supply valve that point downward helps the fluid to drain off to prevent clogging and corrosion.
Simply
  1. Globe valve is used to regulate the flow, but in gate valve it’s not possible. Either it can be fully opened or Fully closed.
  2. In globe valve, flow is controlling by disc. ( looks like cone shaped with cylinderical bottom), in gate valve flow is controlling by wedge. ( looks like taper cylinder -t op & bottom face)
  3. Both will solve the purpose accordingly, however in gate valve leakage will be not there comparing to globe valve.
Except these, all accessories like stem, gland package, bush, gland etc… Will be same.
Note. The above given details are practically observed in beginning of my career in valves manufacturing within the span of 1 year.
