A) An offset is difference between a desired value and an actual value. The phenomenon of a dependent variable assuming a different set of values when the corresponding independent variable is increasing than when it is decreasing is known as hysteresis.
B) Offset is fixed bias from desired value. Hysterisis is difference between set and reset.
