What is the scope of Optical Fiber Liu in infrastructure networking?
Over 2 decades, we have been engaged in manufacturing, assembling, and supplying various range of Optical Fiber LIUs, Fiber Optic Patch Cord, Adapter, Pigtails, Attenuators, Joint Closure and LIU/Patch Panels. Our range contains LC Fiber Optic Patch Cords, FC Patch Cords, SC Patch Cords, ST Patch Cord, SC, ST, FC, LC Adapter, Hybrid Fiber Optic Adapter, MTRJ Fiber Optic Adapter. Optical Fiber Liu is an integrated unit for fiber management, these equipment functions are to fix and manage the fiber optic cables inside the box as well as provide protection. Patch panel provides interconnect or cross-connect capabilities between two units of outside plant, riser or distribution cables, and optoelectronic types of equipment.
For Fabrication we are using quality tested raw material, these are appreciated for compact design, consistent performance, easy maintenance, and user-friendly operation. We offer the product in several specifications and configurations to suits the preference of our clients. Optical Fiber Liu is commonly used to fix and manage fiber optic cables inside the box. Optical Fiber Liu, also known as fiber distribution panel, provides cross-connect and interconnects capabilities for splicing & terminating optic fiber cables, pigtails in the fiber access network.
With our engineering expertise and modern machines, we can manufacture products consistent with set industrial standards. Our professionals are well versed with the latest developments in the market and accordingly manufacture products to meet the demands of several industrial applications. Due to our stringent quality control mechanism, we ensure to deliver flawless products to our clients. Also, our reasonable price and hassle-free payment options have enabled us in garnering a vast clientele across the country and globe. A wide range of Optical Fiber LIU is offered by our organization. This range is widely accepted in the market for its high return loss, low insertion loss, and easy operations. Our cost-competent products are highly reliable and find applications in telecommunication, test equipment, local area networks.
Optical Fiber Liu is ideal for high-density LAN interconnect or cross-connect patching. Highly reliable Fiber patch panels offering user-friendly features that take fiber patching to the next level. Optical Fiber Liu is designed with innovative features that make installation and troubleshooting of fiber optic connectivity faster, easier, and more cost-effective.
Features:
  • Compact size perfect for limited space enclosures
  • MS/Aluminum housing with 7 tank process powder coating
  • Suitable for DIN-Rail and surface mount applications
  • Replaceable panel for SC/ST/LC/FC type couplers
  • Allow a maximum of 2 to 6 cables entry based on models
  • Patch or fusion splice field termination standard
  • Splice holder for pigtail splicing
  • Because of its compact and ruggedly designed case, it is suitable for industrial applications.
  • Available with metal DIN-Rail mount for Industrial high-temperature conditions and applications
Applications:
  • Oil & Gas Industries
  • CCTV & Surveillance Applications
  • Rail Signalling&Control Applications
  • Process Automation & Control Systems
  • Power Systems & Controls
