What is the significance of vector grouping in Power Transformers?
Every power transformer has a vector group listed by its manufacturer. Fundamentally it tells you the information about how the windings are connected (delta or wye) and the phase difference between the current and voltage. EG. DYN11 means Delta primary, Wye Secondary and the current is at 11 o clock referred to the voltage.
