What is the starting torque?
Starting torque is the amount required to overcome the inertia of a standstill. Pull-up torque is the minimum torque generated by a motor as it accelerates from standstill to operating speed.
If a motor’s pull-up torque is less than that required by its application load, the motor will overheat and eventually stall.
