liquid level indicators allow instantaneous reading of the liquid level of a tank or tank. Any variation in the level is observable through the ice wall of the indicator. We have a wide range of level indicators that respond to your applications and your needs according to the parameters you have defined such as service, pressure, temperature …
Transparency level indicator
The reading of the liquid level on this model is done by means of two transparent glasses. The transparency level indicator is especially recommended for colored liquids, water vapor and fluid level reading of interfaces.
It consists of a body with liquid chamber and one or more openings on the sides, as shown on the right in the figure. On each opening, a clear-level measuring glass is hermetically sealed with gaskets between the metal coating and the body of the device and secured with bolts and nuts.
