A full resistance two-wire bridge with RTD, power source, zero and sensitivity adjustments balanced at some reference temperature.
Heating or cooling causes a resistance change and discrete circuit unbalance, which indicates the temperature.
Various RTD bridge network connections use 2-, 3-, or 4-wire hook-up arrangements, depending on the accuracy required in the temperature measurement.
These are designed to balance out lead wire resistance between the sensor and the bridge.
