Zero suppression is a condition of which zero value of the measured variable is less than the lower range value.
Zero suppression occurs in level measurement using DP transmitter installed below the lower process taps.
In this condition, the fluid in the impulse line or capillary gives positive pressure on the transmitter which cause the the DP transmitter provide positive pressure reading.
