What maybe the reasons, if a compressor bearing temperature increases?
The following are possible for compressor bearing temperature rise:
  • Defective bearing
  • Low lube oil supply pressure
  • Aged lube oil
  • Excessive compressor load
  • Dirty lube oil cooler
  • Lube oil cooler fan running at low speed
  • The defective thermostatic valve in the lube oil to cooler line
  • …etc.
