When the circuit components are either large, remote from each other, or numerous in a given electrical-power distribution system or control process drawing, the ___ wiring diagram is an ineffective way to relay the required information
When the circuit components are either large, remote from each other, or numerous in a given electrical-power distribution system or control process drawing, the _______________ wiring diagram is an ineffective way to relay the required information.
A different type of drawing, called the _________________ diagram, which displays only the electrical control sequence, normally is used.
The electrical sequence of events is presented in the most straightforward method possible.
A) pictorial; pictorial
B) elementary; pictorial
C) pictorial; elementary
D) elementary; elementary
Show Answer
Answer:C
