When the fuse, circuit breaker, or control switch is __________, the circuit or power-supply voltage appears as voltage drop across the is __________ device (assuming the load is still connected and provides circuit continuity); the load voltage goes to zero; and the flow of load current stops.
A) open; close
B) open; open
C) close; open
D) close; close
Show Answer
Answer:B
