When two D.C. generators are running in parallel an equilizer bar is ___
When two D.C. generators are running in parallel an equilizer bar is used
A. to increase the series flux
B. to increase the generated e.m.f.
C. to reduce the combined effect of armature reaction of both the machines
D. so that the two identical machines will pass approximately equal currents to the load
Show Answer
Answer: D
Share your understanding of this question with the correct explanation.c
