When two single phase transformers are running in parallel and if the impedance triangles of the transformers are not identical in shape and size then
A. power factor of one transformer and power factor of common load will be same
B. power factors at which the transformers operate will be different from one another and again these will be different from power factor of common load
C. power factors at which the transformers operate will be same but different from power factor of common load
D. power factors at which the transformers operate and power factor of common load-all will be same
Show Answer
Answer: B
