Which of the following is correct statement ___
Which of the following statement is correct
A. The emitter injects holes into the base region of the PNP transistor and electrons into the base region of the NPN transistor
B. The emitter injects electrons into the base region of the PNP transistor and holes into the base region of the NPN transistor
C. The emitter junction is reverse biased in the NPN transistors and forward biased in NPN transistor
D. None of the above
Show Answer
Answer: A
