Is the valve actually leaking? In most cases, the leaking is caused by an outside source affecting the valve.
A few troubleshooting questions that may help address this issue are:
Is this a new installation or repair?
Is the valve installed vertically?
Is the installation piping (inlet and outlet) correct?
Has the system been recently changed or modified (including the valve manufacture and model)?
Is a proper operating gap being maintained?
Have pressure-measuring devices been calibrated recently?
Where is the pressure measurement being sampled in relationship with the valve and is there a correction required for pressure differences between the two areas?
Does the valve exhaust into a single exhaust or a common header?
Is the system seeing any vibration?
Was the valve opened in an over-pressure condition? If so, how many times?
