Gas turbines and compressors are high speed rotating equipment. On equipment when vibration exceeds the manufacturer limits can cause sever damage to both itself and to its associated components/parts. Hence it is important to measure and monitor vibration on the running equipment. Generally a high vibration pre-alarm and shutdown limits are set as per the manufactures recommendations.
