WIRELESS MOUSE CONTROLLED DISH ANTENNA
Objective of the project is to control the dish antenna position according to the mouse movement through zigbee transmission with help of microcontroller.
Scope:
In current process dish antenna is controlled manually by men or some wired remote. It’s difficult to change the position of the dish in a short time. So this project overcomes this problem.
WIRELESS BUILDING HEALTH MONITOR
Objective of the project is to monitor the health of the building through zigbee transmission with help of microcontroller.
Scope:
Nowadays there are so many buildings are become weak due to high temperature and increase of moist level. To avoid these kinds of problem we need to notice the building’s temperature and moisture status. In order to do that microcontroller is placed inside the wall of the building with sensors and zigbee. Through zigbee communication we can monitor the temperature, vibration and moist of the building from pc itself.
WIRELESS SENSOR NETWORK FOR POLICE PETROL
The objective of this project is to track the location using GPS receiver for the police patrol.
Scope:
In the last decade the number of deaths and fatal injuries from traffic accidents has been increasing rapidly. So, to avoid this, automatically transmit GPS (Global Positioning System) location to the police station with in a second. They will find the exact location by latitude and longitude values. The alarm will ON with the help of driver circuit when accident place reaches.
REMOTE RIVER LEVEL SENSOR NETWORK
The objective of this project is to monitor the river water level using the flow sensors and display on the LCD Display.
Scope:
This paper evaluates an automated water level monitoring network. This network contains multiple nodes on which measuring modules are installed. These modules collect raw data and transmit them periodically to a central monitoring system.
This monitoring system monitors and processes the raw data and extracts information. Based on this information, various approximations are made such as water level rise rate, time remaining to exceed the critical level etc. The whole network is implemented as a prototype.
PILGRIMS TRACKING USING WIRELESS SENSOR NETWORK
The objective of this project is to track location of the pilgrims using zigbee and monitoring in pc with the help of google map.
Scope:
In last decades if someone lost their path, it is so difficult to find their location but, by using this technique easily find their paths and rescue is very easy buy tracking GPS location.
We can track not only pilgrims path can also track anyone who having GPS receiver with them. GPS will provide latitude and longitude value, we can get the exact position by plotting these latitude and longitude in google map.
REAL TIME CROP FIELD MONITORING USING ZIGBEE
Objective:
The objective of this project is to monitor the temperature, PH and moister.
Scope:
In this project we are continuously monitor the temperature, PH and moister by the help of temperature sensor, PH sensor and moister senor. These values are continuously received to the PC. In we can monitor these parameters.
AD-HOC NETWORK BASED FLOOD MONITOR AND ALARM
Objective:
The main objective of this project is to monitor the flood using flow sensor. Flow sensor is used to measure the flow rate of the water.
Scope:
It is one of the best methods to identify the flood. This project consists of two flow sensor at different places, and to monitor the flow rate of water. If the flow rate is increased above the set rate in the two locations, the alarm will indicate and inform that flood.
TOUCH SCREEN AND ZIGBEE BASED CONTROL SYSTEM FOR APARTMENTS
Objective:
The objective of this project is to control the appliances through touch screen and ZIGBEE.
Scope:
In this project we are controlling the home appliances with the help of touch screen and ZIGBEE. The different places in touch screen produce different values. These values will transmit through ZIBEE. In the receiver side ZIGBEE receives and controls the relay.
MULTIPLE WIRELESS ELECTRONIC NOTICE BOARD
The objective of this project is to design the electronic notice board using the LCD and the wireless communication.
Scope:
Now a day’s college and school are using various type of method to convey the message to the student. In this project we convey the message to easily. We are display the data in LCD display. Project consists of two ZIGBEE receiver and two microcontrollers. The LCD display will display while the received data consist of specified symbol or character.
BLUETOOTH BASED HOME APPLIANCES CONTROLLER
Objective:
The objective of this project is to control the home appliances through Bluetooth technology.
Scope:
In this project we are controlling the home appliances with the help of Bluetooth. One part of Bluetooth device is connected with PC. Another part is connected with controller. The commands sends from the PC is transmitted through Bluetooth device. After receiving the commands in the receiver Bluetooth, the commands are given to the microcontroller. According to the commands the home appliances will control by the help of relay.
