Working of magnetic meter
An electric potential is developed when a conductor is moved across the magnetic field. In most electrical machinery the conductor is a “wire”; the principle is equally applicable to a moving, electrically conductive liquid. The primary device of commercial magnetic meters consists of a straight cylindrical electrically insulated tube with a pair of electrodes nearly flush with the tube wall and located at opposite ends of a tube diameter.
A uniform a.c. magnetic field is provided at right angles to electrode diameter and to the axis of the tube. The a.c. voltage developed at the electrodes is proportional to the volume flow rate of fluid, and toa magnetic field strength. This device is limited to electrically conducting liquids. The magnetic meter is particularly suited to measurement of slurries and dirty fluids, since there are no location for solids to collect except the walls of the tube itself.
