Which of the following statements is correct?
A. The magnetic flux inside an exciting coil is lower than its outside surface
B. The magnetic flux inside an exciting coil is zero
C. The magnetic flux inside the exciting coil is greater than its outside surface
D. The magnetic flux inside the exciting coil is same as on its outside surface
Show Answer
Answer: D
