A DP transmitter is used to measure the level of a liquid, with density 1000 kg/m3 in a closed tank, that can store liquid to a maximum level of 5 meter.
The DP transmitter is installed 1 meter below the bottom of the tank. Calculate the input differential pressure to the DP transmitter when the tank is empty and when it is full.
