Explain the contact selection on high and low pressure alarm switches? And explain why?
On a high pressure switch, the wiring is terminated on the “common” and the “normally close” contact terminals.
On a low pressure switch, the wiring is terminated on the “common” and the “normally open” contact terminals.
This type of contact termination is done to achieve a close contact from the switch during a normal (healthy) process condition which is a fail safe method.
