UNISOL Rack mount patch panel is suitable for 19” Rack frame applications where the Fiber optic backbone cable has to be terminated and had an option for sliding for easy maintenance. Rackmount patch panel slide-out tray holds 2 adapter panels and It can accommodate 48 port in 1U size where there is space constraint in the rack. The Fiber spool provides a minimum bend radius and the splice tray provides protection for splice joint. Our Rackmount panel is suitable for easy pull-in & pull-out to manage the interior of fiber LIU.
Rackmount patch panel is an integrated unit for fiber management, we offer rack-mounted fiber optic patch panels, this equipment function is to fix and manage the fiber optic cables inside the box as well as provide protection. Our Rackmount patch panels are made with 16-gauge mild steel with corrosion-resistant seven tank process powder coating to provide excellent protection for the inside fibers. These Rackmount patch panels can accommodate up to 2 modular panels and is equipped with cable spool to limit bend radius and enhance strain-relief control. Unisol fiber enclosures are designed to accommodate a maximum of six cable entry. It can support up to 48 ports when fully loaded with SC Duplex or LC Duplex Adapters. Rackmount patch panel provides cross-connect and interconnects capabilities for splicing & terminating optic fiber cables, pigtails in the fiber access network. These Patch panels can be loaded with a variety of adapters like ST, SC, FC, and LC.
Application:
- Indore Premise Networks
- Central offices (FTTx)
- Data Centers
- Telecommunication Networks
- Security Surveillance Applications
- Process Automation & Control
- Systems
- Power Systems & Controls
