PID Controllers Pros & Cons
When does Proportional (p.) Integral (I) Derivative (D) Controllers are Used ?
When Proportional (P) Controller is Used during the following conditions:
  • Load Changes are small
  • Offset (error exist due to difference between steady state value and desired value) can be tolerated
  • The process reaction rate is such as to permit a narrow proportional band. Since this reduces the amount of the offset
When Integral (I) Controller is Used during:
  • When the offset must be eliminated
  • Integral saturation due to sustained deviation is not objectionable
When Derivative (D) Controller is used:
  • Large transfer or distance velocity lags are present
  • It is necessary to minimize the amount of deviation caused by the system changes
When Proportional plus Integral (PI) Controller is used when:
  • System changes is small
  • Offset must be eliminated
  • No objection on the recovery duration
When Proportional and Derivative (PD) controller is used:
  • When the system changes are small
  • Improve the recovery time
  • When system lags are high
When Proportional, Integral and Derivative (PID) Controller is used when :
  • System changes are small
  • Fast recovery time
