Precise Process Control System control with Valves
Some process control system’s control loops require highly accurate control in the face of severe disturbances. Ideally the control valve should have low friction, no backlash, and a stable flow pattern.
• Rotary valves, such as high-performance butterfly and plug valves employing low friction bearings and packing’s provide good control.
• Ball valves have large backlash and are not recommended.
• Linear motion valves, such as globe valves cannot match the low friction of rotary valves and must be critically evaluated.
