Process of Refining Crude Oil
The Process of Refining Crude Oil
oil-distillation
In the early days of the oil industry, the methods for refining oil were very different than the methods we use today. People like Samuel M. Kier used horizontal cylindrical stills that only held 5 to 6 barrels of oil at a time. Using the stills, refiners were able to raise the temperature of the oil very slowly. As the temperature rose, they removed the distillates like gasoline for which they had no use, procuring only the lamp oil or kerosene. Over time, oil’s other distillates became useful and the refining process evolved.
Today, pipelines, railroads, tankers, and trucks transport crude oil to refineries where it is transformed into the products we use every day. Oil refineries seem like they would be dirty places, but most governments have placed restrictions on how refineries dispose of waste products and what they can emit into the air. There are many environmental programs that have made oil refining a safer, cleaner industry.
oil-cracking-hydrotreating-process
Once it enters the modern refinery, crude oil goes through a process called fractional distillation . This process separates the different components of crude oil so that they can be further refined. Fractional distillation begins when the crude oil, which is a mixture of different hydrocarbons, is put into a high-pressure steam boiler. This is a tank that makes the oil boil and turn to vapor, much like boiling water turns into water vapor. The crude oil is heated to temperatures up to 1112° Fahrenheit.
After the oil becomes vapor, it enters the bottom of the distillation column through a pipe. The distillation column is a tall tank that contains many plates or trays. The vapor rises in the column, cooling as it rises. The specific vapors cool at their boiling points and condense on the plates or trays in the column. Much like water condensation on the outside of a cold glass, the vapors turn into liquid fractions as they condense. The liquid fractions flow through pipes and are collected in separate tanks. The fractions include gases, naphtha, gasoline, kerosene, diesel fuel, lubricating oils, heavy oils, and other materials.
From here, the liquid fractions are transported to other areas of the refinery for further processing.
Products from Petroleum
12
The products refined from the liquid fractions of crude oil can be placed into ten main categories. These main products are further refined to create materials more common to everyday life. The ten main products of petroleum are:
Asphalt
Asphalt is commonly used to make roads. It is a colloid of asphaltenes and maltenes that is separated from the other components of crude oil by fractional distillation. Once asphalt is collected, it is processed in a de-asphalting unit, and then goes through a process called “blowing” where it is reacted with oxygen to make it harden. Asphalt is usually stored and transported at around 300° Fahrenheit.
Diesel
Diesel is any fuel that can be used in a diesel engine. Diesel is produced by fractional distillation between 392° Fahrenheit and 662° Fahrenheit. Diesel has a higher density than gasoline and is simpler to refine from crude oil. It is most commonly used in transportation.
Fuel Oil
Fuel oil is any liquid petroleum product that is burned in a furnace to generate heat. Fuel oil is also the heaviest commercial fuel that is produced from crude oil. The six classes of fuel oil are: distillate fuel oil, diesel fuel oil, light fuel oil, gasoil, residual fuel oil, and heavy fuel oil. Residual fuel oil and heavy fuel oil are known commonly as navy special fuel oil and bunker fuel; both of these are often called furnace fuel oil.
Gasoline
Almost half of all crude oil refined in the United States is made into gasoline. It is mainly used as fuel in internal combustion engines, like the engines in cars. Gasoline is a mixture of paraffins, naphthenes, and olefins, although the specific ratios of these parts depends on the refinery where the crude oil is processed. Gasoline refined beyond fractional distillation is often enhanced with iso-octane and ethanol so that it is usable in cars.
Gasoline is called different things in different parts of the world. Some of these names are: petrol, petroleum spirit, gas, petrogasoline, and mogas.
Kerosene
Kerosene is collected through fractional distillation at temperatures between 302° Fahrenheit and 527° Fahrenheit. It is a combustible liquid that is thin and clear. Kerosene is most commonly used as jet fuel and as heating fuel. In the early days of oil, kerosene replaced whale oil in lanterns. In the early 21st century, kerosene was used to power New York City Transit buses. Now, kerosene is used as fuel in portable stoves, kerosene space heaters, and in liquid pesticides.
Liquefied Petroleum Gas
Liquefied petroleum gas is a mixture of gases that are most often used in heating appliances, aerosol propellants, and refrigerants. Different kinds of liquefied petroleum gas, or LPG, are propane and butane. At normal atmospheric pressure, liquefied petroleum gas will evaporate, so it needs to be contained in pressurized steel bottles.
Lubricating Oil
Lubricating oils consist of base oils and additives. Mineral oils are manufactured by special processes called: solvent extraction, catalytic dewaxing, hydrocracking, and isohydromerization. Different lubricating oils are classified as paraffinic, naphthenic, or aromatic. Lubricating oils are used between two surfaces to reduce friction and wear. The most commonly-known lubricating oil is motor oil, which protects moving parts inside an internal combustion engine.
Paraffin Wax
Paraffin wax is a white, odorless, tasteless, waxy solid at room temperature. The melting point of paraffin wax is between 117° Fahrenheit and 147° Fahrenheit, depending on other factors. It is an excellent electrical insulator, second only to Teflon®, a specialized product of petroleum. Paraffin wax is used in drywall to insulate buildings. It is also an acceptable wax used to make candles for the Jewish Menorah.
Bitumen
Bitumen, commonly known as tar, is a thick, black, sticky material. Refined bitumen is the bottom fraction obtained by the fractional distillation of crude oil. This means that the boiling point of bitumen is very high, so it does not rise in the distillation chamber. The boiling point of bitumen is 977° Fahrenheit. Bitumen is used in paving roads and waterproofing roofs and boats. Bitumen is also made into thin plates and used to soundproof dishwashers and hard drives in computers.
Petrochemicals
Petrochemicals are the chemical products made from the raw materials of petroleum. These chemicals include: ethylene, used to make anesthetics, antifreeze, and detergents; propylene, used to produce acetone and phenol; benzene, used to make other chemicals and explosives; toluene, used as a solvent and in refined gasoline; and xylene is used as a solvent and cleaning agent.
