An alarm based on the rate of change in the measured process variable.
If the PV changes at a rate greater than the defined rate of change alarm level, the alarm will be activated provided that the rate of change is higher than this level for longer than the minimum duration of change time. If the duration is less than this time, the alarm will not activate no matter how fast the rate of rise is.
