The key questions which need to be answered before selecting a rotameter are:
What is the minimum and maximum flow rate for the flow meter?
What is the minimum and maximum process temperature?
What is the size of the pipe?
Would you like a direct reading rotameter or is a look up table acceptable?
What accuracy do you need?
Do you require a valve to regulate the flow?
Will there be back pressure?
What is the maximum process pressure?
