RS232 & RS449 standards
RS232 standard(considering Motorola ACIA-Asynchronous communication interface adapter IC )
  • RS stands for Recommended Standards
  • Serial data is sent through TxD line.
  • It requires output voltage level of driving amplifier for mark (logic 1, between
    -5V & -15 V) and space ( logic 0, between 5V &15V).
  • The terminating circuit receive data on receiver side through RxD line.
  • For control signal , voltage value is same but logic is positive i.e., for logic 1 it is between 5V & 15V and for logic 0 it is between -5V & -15V.
Main control signals are:
1.Request to send(RTS):
  • Send by UART to MODEM
  • MODEM responds by asserting clear to send (CTS).
  • The purpose is to provide handshaking between modem & UART.
2.Carrier detect (CD), data carrier detect (DCD) or receive line signal detect(RLSD)
  • When MODEM detects RTS from UART one of its response is to send mark logic 1 to telephone line, it responds by asserting CD.
  • UART detects CD & interprets that remote station is online & data link is complete.
3.Data terminal ready(DTR) from DTE and data set ready(DSR) from MODEM
  • It informs data link are electrically ready to establish data link.
  • MODEM asserts DSR saying that it is ready.
4.Common signal return
  • This establish common signal reference point between MODEM & DTE.
5.Ring indicator(RI)
  • It is asserted by modem capable of detecting incoming telephone ring.
  • DTE connected to auto answer mode responds by asserting RTS line beginning process to establish link.
  • Remaining lines are used for signalling & timing control for modems requiring data synchronization.
  • Secondary data rates are smaller used for acknowledgement in opposite direction of data channel.
Electrical and physical specifications:
  • Maximum ±25 V can be applied to line.
  • Cable impedance ( 330 maximum line drivers & 7000 load circuits)
  • Maximum line capacitance 2500pf.
  • Capacitance per foot must not exceed 50pf/foot.
  • Maximum cable length 50 feet due to capacitance specifications.
RS449 interface
  • It has two connectors: 37 pin main connector & 9 pin secondary channel connector specified by RS449 channel.
  • Increased pins share same functions as RS232, with reduced line capacitance.
  • It allows data rates of 2 Mbps & cable length of 200 feet.
New control functions include:
  • Local loop(LL), data placed in TxD line is looped back through MODEM onto receiver
    side to DTE.
  • For local equipment remote loop back (RL),data sent by station is looped back to sending station.
  • In remote loopback DTE is not involved.
  • A similar control signal data mode(DM) indicates data is in normal transfer mode.
  • If DTE desires to prepare DCE to receive new signal line(NS), cause receive data line(RD) to mark state & disables carrier detect(CD) line.
  • Once MODEM receives new signal, it places receive data line & asserts CD line.
  • The send common(SC) & receive common(RC) indicates direction in which data flows.
Reference: Analog & digital communication by Michel Miller
