The 3-phase AC, 3-wire, wire-wound rotor induction motor is symbolized with two _________________ circles.
The ___________ circle symbolizes the stator circuit with three supply lines.
The ___________ circle symbolizes the rotor circuit, which is _________ - _________ -connected to a secondary resistance load bank.
The three secondary lines indicate the _________ - _________ supply lines to the resistive load bank.
A) concentric; outer; inner; slip-ring; slip-ring
B) outer; inner; concentric; slip-ring; slip-ring
C) inner; slip-ring; slip-ring; concentric; outer
D) none of the answers
E) slip-ring; concentric; outer; inner; slip-ring
Show Answer
Answer:A
