The ground-fault return path of the electrical-power distribution system is referred to as the ____________________________ system ― a conductive path installed to connect normally non-current-carrying metal parts of equipment together and to the system grounded conductor or to the grounding-electrode conductor, or both.
A) equipment-grounding
B) none of the answers
C) connections-grounding
D) tools-grounding
Show Answer
Answer:A
