There is a constant homogeneous magnetic field pointing in a ___
There is a constant homogeneous magnetic field pointing in a vertical direction.
A metallic wire in the form of a square is rotated about a horizontal axis passing through the middle points of its opposite arms.
The emf generated in the square is
A. zero.
B. finite and constant.
C. oscillatory.
D. varying with time t as t2.
Show Answer
Answer: C
