Test your technical skills on thermal power plant with our multiple choice questions and answers with an online practice examination.
Top 10 Thermal Power Plant Multiple Choice Questions
The below-mentioned multiple choice questions and answers on thermal power plant.
In Thermal Power Plant the feed water coming from economizer is heated using:
A. HP steam
B. LP steam
C. re heater
D. flue gases
The efficiency of the boiler in modern thermal power plant will be of the order of:
A. 40%
B. 50%
C. 85%
D. 60%
Steam in thermal power plant is super heated in order to:
A. improve the Rankine cycle of efficiency
B. Reduces initial condensation losses
C. avoid too high temperature in the last stage of the turbine
D. all the above
The advantages of the reheating steam in the turbine is that:
A. It increases the efficiency of the turbine
B. It reduces the wear on the blade
C. It increases the work done through the turbine
D. all the above
In thermal power plant cooling tower is used to cool:
A. Condensate outlet water
B. Exhaust steam
C. Cooling feed water
D. all the above
The purpose of the condenser in thermal power plant is to:
A. Condensate the large volume of steam to water to be used as boiler feed water
B. Maintains pressure below atmospheric pressure so that maximum heat energy can be extracted from the steam
C. Receives large volume of steam exhausted from the steam turbin
D. All the above
The purpose of air pump in condenser is to:
A. remove water
B. remove air leaking in to condenser to maintain vacuum
C. maintaining atmospheric pressure in the condenser
D. both (A) and (B)
The modern steam turbines are:
A. reaction turbine
B. impulse turbine
C. impulse reaction turbine
D. none of the above
In coal preparation plants, the magnetic separators are used to remove:
A. dust
B. iron particles
C. clinkers
D. both (B) and (C)
In steam power plant is coal is carried from storage to boiler by means of:
A. trolleys
B. V-belts
C. buckets
D. conveyers
Share your understandings of these questions with the correct answers.
