Transfer function technique is inadequate when the ___
Transfer function technique is inadequate when the system has
A. stability problem and needs compensation
B. multiple input disturbances, complexity and non-linearities
C. difficult trial and error solution and its optimal solution is desired
D. desired solution directly in time domain along with information for its internal states
E. All of the above
Show Answer
Answer: E
