Two generators A and B running in parallel are supplying power to ___
Two generators A and B running in parallel are supplying power to a common load of 500 kW.
Generator A has armature resistance equal to half that of B.
Which of the following statements is correct ?
A. Both generators will share load equally
B. Generator A will take load less than the load taken by generator B
C. Generator B will take more load as compared to generator A
D. None of the above
Show Answer
Answer: D
