A material that is harder than the surface to which it is applied. It is normally used to resist fluid erosion or to reduce the change of galling between moving parts. Hard facing may be applied by fusion welding, diffusion, or spray coating the material. Alloy #6 or Stellite is a common material used for this purpose.
