What is a clean agent?
Clean agents extinguish fires using an electrically nonconductive gas. This makes them uniquely suited to protecting sensitive electronic equipment and other high-value assets present in your building. Clean agent fire suppression systems are ideal for extinguishing fires in small spaces such as cabinets or the inside of equipment as well as for large-scale applications such as semiconductor facilities or data centers. Clean agents do not leave behind a residue, eliminating the need for time consuming clean up.
Apart from the above good write up, clean agents are really good selection for extinguishing fires for below reasons.
Can be used for any size of the rooms.
Eco friendly.
Safe for humans.
Safe to electronics.
Typical clean agent systems are
• FM-200 Clean Agent Fire Suppression System
FM200 fire suppression is also known as HFC227ea. FM200 is a waterless fire protection system , it is discharged into the risk within 10 seconds and suppresses the fire immediately.
• Novec 1230 Clean Agent Fire Suppression System
Novec 1230, C6F12O , (3M Novec 1230) fluid is a low global warming potential Halon replacement for use as a gaseous fire suppression agent. Novec 1230 is manufactured by 3M
• INERGEN Clean Agent Fire Suppression System
Inergen is made up of with a blend mix consisting of Argon 50%,Nitrogen 42% and CO2 8%
