Which device the load current will be maximum?
There are a Transformer and an induction machine. Those two have the same supply. For which device the load current will be maximum? And why?
Answer:
The motor has max load current compare to that of transformer because the motor consumes real power… and the transformer is only producing the working flux and its not consuming… hence the load current in the transformer is because of core loss so it is minimum.
