Which of the following statements is incorrect ?
A. If a system output is an oscillatory signal for a sinusoidal signal, it is called relatively stable
B. If a system response is stable for a limited range of variations of its parameters, it is called conditionally stable system
C. If a system response is stable for all variation of its parameters, it is called absolutely stable system
D. If the output response to a bounded input signal result in constant amplitude or constant amplitude oscillation, then the system is limited stable
Show Answer
Answer: A
